Car cuts out and stumbles when starts to hit boost
Turbo317
I recently put alot of new upgrapgrades on my car over winter. and im currently driving in around a little bit with just the THDP on the exhaust. But my question is, when i start to get on it at 1st it just wants to go, but the boost starts to pic up and starts to a little more but then it starts to stumble and dies out, and i can get no more than maybe 5 lbs of boost going before it stumbles. i put a new maf on last fall, fpr was a 42 last time i checked, tps at .46 .. any ideas on why it stumble?? would the computer need a certain amount of running time to relearn with all my upgrades??
thanks,
Bryan
My car only needs about 20 minutes or so driving time to relearn.I think it could be ignition related.What about a cat,are you running one.Mine also did this when I got it.The cat was clogged.When I removed it my car spooled like mad.before it would only get 10# with the wastegate all the way in!
Check to see if the passenger side exhaust header is hitting/shorting out on the positive battery cable..
my GN is doing the same thing. im going to test the coil pack this weekend.... buying a new fuel pump this weekend too :D i cant describe how much of love the GN :)
