trophystock
- Sep 17, 2003
I took my TTA down the road today for the first time in about 3 months. It started fine and ran good for about two miles then simply quit. I limped to the gas station (gauge was on empty and I was thinking it was out of gas) and put 10 gal. in. It then started up fine and ran well for another mile or so then simply quit again. It will always fire up and idle but will not take any throttle at all. It is like a carb that is simply sucking the bowl dry. The longer I let it set the longer it will run well when I start it back up. It idles fine but quits while I am driving down the road at a steady throttle. I put a fuel pressure gauge on it and and has good pressure. I changed the stock chip out for a thrasher chip but it didn't help. I swapped MAS out with another but no help. I did see on the scan tool my CTS go to 300* for a second so I swapped it out for a new one. I have no trouble codes except for a "high coolant temp error". Any ideas? I will start checking grounds in the morning and start looking at the TTC also.
Thanks,
Charles
Thanks,
Charles
