Ok, I filled up my car, drove down to the races (about 70 miles), and the car was running fine. Car sat for most of the day, fired her up, and drove back home..After about 5 minutes of driving, the car started to stall out..It would stall out escpecially when Im coasting at the lights..So then, I would pull over and have a hard time starting it..Let it sit for a few minutes, and it would start then...then drive for 2 minutes, and it would cut out again...Did this cycle for about 1/2 hr, it felt like the car was not getting gas...Im thinking great, maybe its a bad crank sensor?
Im thinking maybe it was the MAF, so I disconnect it and drive the car, same thing (kept cutting out)...So, I pull into the gas station and figured Id get gas and see what happens..To my surprise, it took 10 gallons
(even though I only drove the car about 70 miles)..Also, my digital gas gauge said I had 12 gallons still. Im thinking wow, this car got the crappiest gas mileage...So, on I go leaving the gas station, and the car ran fine!
In the past, I would let the gauge go down to showing 2-4 gallons, and the car ran fine still..
Is it possibly a clogged gas filter? Im thinking maybe I got crappy gas from the 1st fill-up in the morning? The tank still had at least 6 gallons in the tank before I had to fill it up again, so the stalling problem was not because I had no gas in the tank...
I replaced the gas filter about a year ago with a GM one, I guess it got clogged? Is this the typical symptoms of a bad/clogged filter? With a clogged filter, wouldnt the car not be able to idle at all? My car idled ok before I got the second gas fill-up..
