car goes to the side during burnouts?
blackstallion
When i do burnouts the rear end of my car goes to the right does this mean i some sort suspension problem it looks cool though?T-top car we-4
Well, your posi is working fine. Maybe you need to get just out of the water and stay in the little grooves. If I stay in the water from the box, I tend to go to the right myself.
Another thing. Keep the RPM's low. I normally let the car shift itself in D and keep cooking them at lower RPM's......I drive to the track w/ dot slicks and bust off 1.5's for 60ft's.100% stock suspension.
HTH
Bo
the reason for this is because you are too far in the water box... the ideal burnout would be to back into the waterbox full, but do not put the front tires in, and then pull out of the box fully, about 2-3 inches out of the box... The reason it slides is because it is too wet... Imagine doing doughnuts in the snow... no snow means grabbin, but once you hit the snow you slide around...
So like i said.. pull out about 2-3 inches... and that will allow for a perfect burnout.. You might need to give a little more throttle!
Happy Burnouts!
Brian
