Ok, ive never had a starting problem until today. I had to keep cranking over the car and it finally started..
The battery/alternator is ok, and I have a newer mini-starter (starter easily engages), so those things have nothing to do with the problem. Also, once the car is started, it runs fine (i.e. fuel pump is obviously ok)..No driveability issues and all the Scanmaster readings are ok..
Can it be a sensor thats going bad?
Maybe the coil pack? (but this is a fairly new one, along with new plugs and wires...)
Maybe the ignition module (i never replaced it, just the coil pack)...
Whats the usual culprit when the car is hard to start (but turns over easily and battery voltage is ok)....
