Jul 3, 2009 #1 G gnryder New Member Joined Jul 3, 2009 Messages 7 car was running and just shut off. now it wont crank
Jul 3, 2009 #3 Q Quick6'n'-K.C. wana steal it? meet mr9mm Staff member Joined Nov 24, 2001 Messages 11,267 crank trigger or coil pack and module Its possible the cgii or some fuse popped on the car to keep the module from firing. Look under the dash and test each fuse, if the cgii fuse is bad, the coil pins ate into the module BW
Jul 4, 2009 #4 J Just a Six?? OK! Who Farted?? Joined Jul 4, 2003 Messages 3,574 Also take the plastic cap off cam sensor & make sure its all tight & the pin isn't busted. If so RJC sells a repair kit. Also as mentioned the coil pac. Open it up & make sure it didnt turn into Goop!
