I have an '86 GN that I just dropped my rebuild 109 stroker motor in. The car runs but it sounds off.
The car has a rough start. When it's cold, I have to keep giving it gas while it cranks and cranks. After a few seconds it starts to fire then it gets better and better till it stays running on its own. When the car is running it sounds like a tractor. It lacks that distinct GN sound. It sounds like the timing is off but I have pictures of the timing chain lined up inside the motor and have set the Cam Sensor three times, so I know its in time. But when it sounds like a Hi-Lo I know something isn't right.
I need some HELP! I have changed the coil pack and module, new o2 sensor, changing computers, resetting the cam sensor, and changing mass air flows sensors. Some of the things I've tried has helped the car run better but it still has that overall Hi-Lo sounds. The headers start to really glow red when the o2 read low on the Scanmaster. Fuel pressures good and the TPS is good. I am running out of things to think of.
The thing that I don't understand is, I recently bought the car early this year and had a good running motor and trans it in. When I first brought it home I drove it around and it drove great. Pretty much a stock motor and an Art Car trans with a vigilante converter. Then I set that motor and trans aside and put in my build motor and trans. Now the car sounds like a tractor and I can't build more than 3 pounds of boost when I'm doing a brake torque.
I know something is wrong and I just want that distinct GN sound, I have used both sets of sensors from both set ups to try and see if that was the problem but nothing. I'm hoping you guys can help me!
Here's my set up:
109 '87 GN Block
Forged 3.625 Stroker Crank
Forged Rods
20 over JE Pistons
4 Steel Mains
212/206 Billet Roller Cam
Custom Made Pushrods
1.65 Scorpion Roller Rockers
Fully Ported Champion Aluminum Heads
Fully Ported Intake
70mm Hemco Plenum
70mm Throttle Body
72# High Impedance Injectors
Lt-76mm Turbo
Front mount Intercooler
Hard pipe to Cold Air by TinMan
Alky
Turbo Tweak Chip
ATR Headers
GN1 Down pipe with External Wastegate
2 1/2 Hook Exhaust with Dump
Build 200 4R Trans with a Vigilante 3600 Stall Converter
Thanks for taking the time to read my post. If you have anything please let me know. I have run out of things to think of so anything that I can try would be greatly appreciated.
- Justin
Here's my set up:
109 '87 GN Block
Forged Rods
20 over JE Pistons
4 Steel Mains
Fully Ported Intake
70mm Hemco Plenum
70mm Throttle Body
Lt-76mm Turbo
Alky
Turbo Tweak Chip
ATR Headers
- Justin
