can't figure this one out. car idles rough in park. sounds like it has a big cam in it.
put it in drive and it smooths right out. vac is low in park, about 10''.
cruising and let off gas pedal vacuum will go to 18''.
blm is 120 at idle. fuel pressure is 42#.
idle fluctuates in drive with foot on brake about 50-75rpm's
haven't done a compression check yet. Also hear some slight ticking coming from pass vc. need to pull cover and check rocker arm shaft.
any other ideas let me know. thanks
jeff
jeff
