Darkstar72
- Oct 1, 2017
I just wanted to make a quick post to let the members know my recent findings with my RJC PCV valve. It had been on the car when I bought it last year and I noticed straight away on my first few drives with the car that the idle BLM was at 142, but would come down quickly once moving off idle. I never gave it much more thought as all vacuum lines are in good shape, BLMs were fine in all other driving conditions, and the car ran good otherwise. Upon looking up the topic on the board here I found that others were getting high BLMs at idle with these PCV valves as well without the stock PCV valve in place.
Fast forward a year and I decided with all the virus downtime to put some time into the car. I changed out injectors and chip with the 60 lb combo from TT. I noticed again when idling for the first time that the idle was horrible and after the first drive it was better/about normal. I then noticed on further driving that the cold idle would drop very lean to about 115 sometimes below 100 mV on the SM at idle with a very rough feel. The idle BLM again just pegged at 142 since Eric does not let his chips go past 142 at idle for BLM. I broke out the starter fluid and started spraying areas for potential vacuum leaks - MAF tube checked good, all piping couplers checked good, drivers side intake and hoses no change in RPM, vacuum block area all good, and then spray the PCV area with an immediate rise in RPM. Bingo. I had on the shelf a stock replacement PCV, a US Plastics viton seal check valve to install inline, and a new PCV hose which I had purchased after reading a majority of the prior RJC PCV valve threads. I got it all installed in the car, reset the PCM by disconnecting the orange wire at the battery, and went for a little drive. I’m pleased to report that idle BLM now has dropped to 133 and the idle has greatly improved. I verified this again the next morning on a cold start with open loop idle now enabled after the relearn drive that idle never went lean and idle BLM at 133.
Sorry for the long winded post but wanted to try to help others that may be fighting a lean idle issue and an RJC PCV valve on their car. Spool on!
