1987RegalTurbo
Boost Addict
- Aug 8, 2011
I have an 86' GN that has a few odd issues.  First, every time I start the car, it defaults to the metric system on my digital dash?? Secondly, every once and a while the car will stall after a pull, but start right up after I pull over and restart it.  I replaced my IAC motor and set the IAC count to 25 @ full temp in park, then set the TPS accordingly, still has a stalling issue.  Lastly, the car doesn't seem near as fast as it should.  I have a TE-44 turbo, fuel pump, 42lbs injectors, front mount IC, LT1 MAF with translator, 3" DP and full 2.5" exhaust, TT chip with 20/18 degrees timing and 16-18psi on 93 octane.  Fuel pressure is set properly as well.  The only thing that seems odd is my WG flapper.  I've noticed that with the rod arm off, it occasionally, seems a bit "sticky."  The car makes around 16-18psi in 1st and 2nd gear.  In these gears it seems like the power just isn't there, but once I hit 3rd the boost drops to around 15psi and the car seems to come to life.  The tires won't even think about spinning off the line.  I'm starting to get frustrated as I've methodically combed through the obvious stuff.  Any ideas would be greatly appreciated.
Best Regards,
Derek
			Best Regards,
Derek
