Car starts, then dies immediately.
SS/GNX
Formerly NothinYet
OK.
So, I think my ECM is bad cause my fuel pump wont kick on and I've tested with a volt meter and jump power to the green/white wire that controls the pump right at the harness and it works. I also borrowed a buddy's ECM and the pump kicks on immediately, so that pretty much means I need one.
BUT!!!
My car will still not run. It turns over, fires, then dies out immediately.
I have tried the disarm sequence, same thing.
If anyone has any insight on this problem, I would greatly appreciate it.
Thanks.
P.S. before the ECM stopped turning on the pump I would have this issue.
I'd shut the car off to go get gas, then try to start and it wouldn't. I would try over and over and eventually like the 10th time it would just start and stay running. Very sporatic when it would start, but once I shut the car off it was back to doing the same thing. All I could do was cross my fingers.
Went thru this over the last few days. When cold car would start but once hot it was a bear to try & start. Cool down & it was fine again.
My Module was bad & it was Brand New never used before. Put in the spare & no more issues!
Doesn't matter if its cold or warm actually. Just randomly starts, and randomly does not.
I've tried cold starting it several times with no luck. It has a mind of its own.
Sounds a lot like the anit theft in the chip. Try unpluggin the orange ECM plug by the battery for 30 seconds and try it all over again.
Called Full Throttle had them run the part number and this chip does not have anti theft on it. Rules that out.
Tried new plugs. No luck.
Made a better ground to the fuel pump. No luck.
Bypassed the relay and "hotwired" the fuel pump. No luck.
Tried another coil pack module, not sure if its a known good one, but no change at all.
Have a brand new ECM BTW... no luck.
No, Dont know how to reset the cam sensor. Rick is going to come over someday this week and try a new cam sensor cap.
Maf
Mass air flow, mine did the same.. Try unplugging the MAF and starting it.. if it starts and stays running the MAF is bad..
Den
Den
He is running a MAFless setup. ;)
I have the caspers cam sensor setting tool if you need it. I can also drop off my 60lb pro chip to Rick if you/he thinks that is something to try.
Glen, If I could borrow both of those, I would GREATLY appeciate it.
Rick did mention he wanted to try a chip, and I don't think checking and resetting the cam sensor OR trying the chip is a bad idea at all.
I'll PM you my number, I can pick it up. If you can meet up with Rick conveniently that will work also.
Thanks guys, I really appreciate the help.
Tried cam sensor cap, Map sensor. Nothin.
Had the battery tested. Its fine.
Re-did all the wiring under the hood, took a grinder to anywhere a ground touched metal, new connectors, soldered them, shrink tubed em.
Found one very large ground that was not connected... that was the problem I am pretty sure. Its running again... hopefully it will last!
Glen, I'll drop off your parts I borrowed early next week. Thanks again.
