tpivette89
- Mar 27, 2002
long story short, my car is still running badly even after i troubleshooted and replaced a few items. it hesitates and pops at idle, cruise, or under acceleration. i replaced the fuel pump, and one of the plug wires that had cracked cause it was touching the downpipe.
so this afternoon i took it for a test drive around my neighborhood with a scan tool attached so i could see what my sensors were reading. i recorded seven values: MAF, O2, knock, BLM, coolant temp, IAC, and TPS. heres what i got when driving around the block a few times
1st trip:
MAF - (idle) 9, (cruising at 1300rpms) 16, (part throttle) 51
O2 - switching anywhere from .120 to .870
KNOCK - no counts
BLM - 128
COOLANT - started at 20 and got to around 45 at end of 1st lap
IAC - anywhere from 75 - 130 depending on throttle application
TPS - .44 at idle and went to around 1.8 at part throttle
2nd trip:
MAF - same as above
O2 - same as above
KNOCK - same as above
BLM - 105
COOLANT - got up to 76 and stayed there
IAC - same as above
TPS - same as above
anything look out of place? i know my BLMs were off during the second trip around the neighborhood, but when i gave it gas and got into about 4-5 lbs of boost, the reading jumped from 105 to 128. also, the IAC went down to 0 when i stopped the car and put it into park. is that right?
any help would be greatly appreciated. im getting tired of searching for this mystery problem... i just want to start driving and enjoying this car already
1st trip:
KNOCK - no counts
BLM - 128
2nd trip:
MAF - same as above
O2 - same as above
BLM - 105
IAC - same as above
TPS - same as above
