Brian Farrugia
Guys,
I am new to the forum but have had an 87 GN for 10 years. I recently ran into a problem that i cant figure out and I hope that someone can give me some ideas on what the issue could be.
A little background on the issue: it started when my radiator cracked and some coolant was sucked into the intake. the next day the car would not run for more than a minute with the MAF connected. I know the simple answer here is the MAF and it was an issue as the voltage was bouncing around significantly. I replaced the MAF with a stock rebuilt unit and it seems to function properly (voltage increases and decrease up and down the rpm range) but the problem persists. I cleaned the throttle body so it is not carbon and there does not seem to be a vacuum leak. When I start the car it runs rough and stumbles when you increase the rpms but will smooth out, if you let it drop back to idle the car will bog out and stall. I checked the TPS and MAP sensors and they seem to function properly, i get 5v at all the sensors signal wires and grounds look good too. Again, when you disconnect the MAF the car runs fine using the MAP and TPS sensors only.
Car is mostly stock, has a brand new 350lph fuel pump, turbo has been upgraded and puts out 25psi but it is set to peek at 18, has an 80s chip in it cant tell you much about that. has fuel pressure, boost and knock gauge in it. other than that i am blind.
Thanks for any help!
