Carbed Turbo Part
beygon
I posted this in parts wanted but it might be missed.
I need the rubber grommet that plugs into the back of the intake manifold on a 1979 carbed turbo motor. I think it connects the turbo oil feed back to the engine. Anyone have one of these around?
Please email butterfield56@cox.net
I don't have one to sell, but I hope this helps.
1978/79 used a rigid drain that rested into the "hose" fitting you are referring to. In 1980/83, Buick went to a flexible drain line that fit into a traditional grommet (like a PCV grommet, but bigger). If you can't locate the hose, you might be able to find the flex drain line and grommet at a turbo shop. It's an improved design that should work better (easier installation).
Here the GM part numbers:
1978/79 Drain line (connector) - 1260602
1978/79 Drain hose - 1260599
1980/83 Drain line - 25504159
1980/83 Drain grommet - 25504235
1978/83 Gasket, oil drain line to center section - 1256780
