cars x-count drops with anything but ac o2
tyrod
I have tried the bosch 12014, three different times. I just bought and installed the Nippodenso I have been reading about here. My crosscounts drop to single digits/sec. I have bought the ac and it works fine for twice the money of the bosch. Lead takes it out fairly quickly. Is there any way to adjust this so that I can run the other sensors or will i be ok with less xcounts. wot readouts on the ds look similar to the ac on pump gas. car sounds like it is laboring on the 2-3 shift with some knock immediately after the shift with only 15lbs. Hope there is a solution besides running the ac. I dont want to give up the denso.:(
Maybe not the answer you're looking for, but the casper's heated o2 kit is well worth the $ especially if you use race gas....
chris
My denso has done a lot of leaded and still working fine, at $16 a pop it's worth it!
