As described in the title, the bolt holes on the plate that attaches to the front cover are not lining up to the IC (bolt holes in plate are now higher). My educated guess would be because I am now running a 6766 turbo and not a stock one. I can get one bolt in which I think should be fine. I guess since the turbo is bigger, the IC sits lower in order to line up with the turbo. Just wanted to know if anyone else has had this problem.
