Caspers fuel/oil pressure kit for FAST intall
ringman
Installing caspers fuel/oil pressure for FAST. The directions make no sense to me as for doing the jumper wire on the plug side. Any help or pics would be nice (wires confuse me lol)
there no wires to jump , instructions should have come with your casper XFI-gn adapter box http://www.installationinstructions.com/108135revA.pdf
and with the sensor kit
http://www.installationinstructions.com/109038.pdf
open the casper adapter box (4 small phillips screws ) and in the midle of the circuit board there are 2 plastic jumpers side by side similar to what computer hard drives had , just pull them out and move them up from egr to the xfi sensor position pins
install sensors and plug the connector into the egr plug on your engine harness by driver valve cover
Ok this makes MUCH more sense now i think. I was thinking the plug that went into the egrgit modified. But its the adaptor box inside the car
Looks like mine was already what i want for oil/fuel?
looks like he eliminated the jumper pins .. you're good to go
Thank you so much, easy once you do it....but without instructions i was lost. Thanks again
