I've been noticing more and more as I've been modding and tuning that the Casper's knock gauge goes of like a Christams tree when the scanmaster shows nothing?
It'll dislpay green, yellow then red on the knock gauge with not much boost at all. The 3" DP isn't hitting anything. The light will even come on at low acceleration when the car shifts between 1st and 2nd gear. I turned the car up tonight to 25 lbs of boost. It ran great and the scanmaster showed only .7 degrees of knock at the most. The IAC counts look normal, O2's normal, the MPH is showing accurately so I know the scanmaster is working. Is the Casper's gauge just so sensitive that I'm actually getting knock or is it picking up something else? Any Suggestions?
