Matt Sando
- Jan 13, 2005
Parting out my Camaro hybrid. If your planning on doing a GN hybrid this is the harness for you! I paid 900 for this setup. it is a stand alone harness and has wires to hook up your factory tach, oil, temp, and bat. everything on this harness has been redesigned by Caspers so no ground problems, or fuel pump power problems. This unit only has around 300 miles on it. Other upgrades include VSS module, speed sensor, so your car will still have lock up. Heated 02 sensor set up, and a Caspers knock gauge that ties into the harness. This harness comes with everything you need for wiring a hybrid convrsion totally plug and play! All relays are also heavy duty relays. I will also include the original sales reciept. $750 Shipped
