Cast N/A vs Turbo
HotAirGN
Is there any difference between a turbo stock cast piston and a regular cast such as this
summitracing.com
If there is a difference what is a part number to replace a stock Turbo piston for my 87T?
Summit Racing - High Performance Car and Truck Parts | 800-230-3030
what you want is a 25cc dish piston i believe, for 8:1 compression, these pistons list none of those specs so you may have to call them to get the information. If they are N/A pistons they should be alittle higher compression, maybe upper 8's to a 9:1 but i dont know for sure. hth
So in essence if I get whats in the link I will be as good as stock? No better and no worse?
I have seen several post about guys using the hyper pistons in stock to mild performance rebuilds. I have never used them myself.
I have used the TRW Forged (Now Speed Pro). They are equal in weight to the stock piston when using their pin making them a stock replacement.
I have JE in my current combo.
