Catalytic Converter???
brn agn
Can anyone recommend a place to buy a direct fit catalytic converter for a TTA? After failing the local emissions test, I un-bolted the intermediate pipe on our newly purchased TTA and found out that the converter is gutted. Although, I would like to find a high flow cat, a stock replacement will work too...I would probably install it just for the test and take it off after it is over. Is the TTA converter the same as the one on the Turbo Regals? Thanks in advance!!!
