Bruce,
I know there is a method for checking for a clogged converter, but can you tell if a converter is clogged by Ca smog test readings. I have them if it would help (smog tested less than 300 miles ago). I'm slow to spool and the exhaust note seems a little more quite than my last factory stock WE4. The car runs good but seems to be a just a little sluggish out of the hole. Boost will build up slowly and starts to pick up as the car hits second gear and spin the tire through second then flatten out a just a little bit through the power curve (seems to build boost under much effort). My last car built boost effortlessly. The plugs are grayish white and clean, with 148psi across all cylinders. The car has 62k miles and is factory stock down to the exhaust tips, with no mods, factory chip. I've listened for exhaust leaks and it doesn't seem to have any. The car doesn't pop, fart or ping, no Knock, At first I thought it may be pulling timing for some reason...Man I wish you were closer to Fresno, there are no experts here in town or any where in the Central Valley for that matter. My last car an 87' WE4 would build boost much faster, by the time you were in second you were really pulling hard. As soon as this car starts to pull hard I hit second spinning the rear tire (peg leg) for 20-30 feet.
If I do have the converter tested do I need to remove it first?
Thanks.
Thanks.
