cfm?
This question doesnt make much sense the way its worded. I believe its approx. 1.3 cfm/hp under normal conditions. Figure .5 inch or possibly a lot more pressure drop if you have a factory MAFS. Use the compressor maps to figure out your needs based on your hp goals and boost pressures.
thank you thats exactly what i wanted to know, didnt think that was so difficult :rolleyes:
Yeah. Thats max flow which are not going to get get without a huge pressure drop if you have a small MAFS or run under 28 psi on a stock cammed/headed engine:tongue: .
