Starting a build. Just in shopping mode right now, not in a rush. Looking for the newer castings on these if possible. Not interested in welded or repaired heads. Thanks in advance.
I have a fresh set of ported iron stock heads with all new valves. These heads are comparable to Champion CNC in flow and performance. The stands are machined to use roller rockers if desired.
Contact me direct e-mail for pricing if interested, as it varies depending on your valve spring requirements.
