25lbs
Are you sure you want to try this?? Why?? You do realize it isn't just a matter of "turning up the wick". There are lots of other things involved in making more power.
But, if you want to blow out your headgaskets, here's the boost section of the chip file
77F, 0, 0, 0.0, Wastegate duty cycle vs RPM, 1600
780, 0, 0, 0.0, Wastegate duty cycle vs RPM, 2000
781, AA, 170, 14.7, Wastegate duty cycle vs RPM, 2400
782, AA, 170, 14.7, Wastegate duty cycle vs RPM, 2800
783, AA, 170, 14.7, Wastegate duty cycle vs RPM, 3200
784, AA, 170, 14.7, Wastegate duty cycle vs RPM, 3600
785, AA, 170, 14.7, Wastegate duty cycle vs RPM, 4000
786, AA, 170, 14.7, Wastegate duty cycle vs RPM, 4400
787, AA, 170, 14.7, Wastegate duty cycle vs RPM, 4800
788, AA, 170, 14.7, Wastegate duty cycle vs RPM, 5200
789, AA, 170, 14.7, Wastegate duty cycle vs RPM, 5600
78A, AA, 170, 14.7, Wastegate duty cycle vs RPM, 6000
78B, AA, 170, 14.7, Wastegate duty cycle vs RPM, 6400
That's the stock boost profile BTW.
BTW, even inserting FF(h) in the file will only yeild 22lbs of boost, assuming everything is perfect, and even then you'd need an adjsutable wastegate actuator, cranked way in to get 25# of boost.
I would strongly recommend you learn a whole lot more about what's going on in these chips before you start hacking around, especially with something as radical as turning the boost up so high. If this is an attempt at a race chip then there's lots more to think about!!!
