Changing VE tables, need Guru's
  • Thread starter Thread starter Dave King
  • Start date Start date
D
Dave King
Guest
I'm changing my VE tables for changes in DA.
Is there a way you can change the entire VE
table and then add 2 to each number? Or subtract
2 from each number? It's a pain in the butt
to go to each block on the map and have to do
it by hand. I know that you can select a large number
of cells with the shift and up/down/left/right arrow
keys, but how can you add or subtract a certain
number to each cell?
After highlighting the area you wish to change, simply press the [+] key and a dialog box will pop up prompting for an offset. You can enter a positive number or a negative number to add or subtract to the currently highlighted VE values.
