Charcoal canister
NorCalTurbos
Slowing down to SPEED UP!!!
Someone please help!!! I need pics at the tank or any where near the rear where the vac line for the canister hook up to the fuel pump to make sure I'm hooked up right
I had two fuel pumps in the car when I bought it but it seemed as if they were just trying to bypass the in tank pump
Is this what you need?
Guys please correct if I boo-boo'd. I'm about pass out tired right now.
Thanks that helps.. I'm still looking for the vac line on undercarriage. I found a line on the psngr side above the tank it has a short rubber hose on it going to nothing also there's another line on the driver side rear that's not hooked up
The vacuum line on my car does the same thing. It comes off of the tank and travels up the passenger side of the car.
