spaceturbo
Banned
- Dec 14, 2023
I just installed a new walbro pump new racetronix stainless sending unit along with a new gn tank and hot wire kit. When you turn on the key the pump comes on and shuts off as it should. However it will not pick up the fuel. I pulled the pump out of tank by its self by running a positive and negative. It worked fine. Put it back in the sending unit and back into the tank and still it will not pick up fuel and it has over 5 gallons of fuel. Can someone please help me. Thanks
