b4black
- May 24, 2001
Would 45 psi be enough delivery pressure for an injection system? If so, there are windshield washer pumps that can supply this. Plus they must be methanol compatible since washer fluid is ~1/3 methanol.
I have this set up on my car using a factory windsheild washer bottle (~1/2 gallon). The pump mounts directly into the bottle. Total cost was $8 for both. I spray before the turbo, so 45 psi is plenty. Spraying into 20 psi of boost would leave a ~25 psi differential. Maybe enough with a big M15 nozzle (or two)??? If so, this could be a very low cost system.
