SneakyPete
- Feb 4, 2004
Here is my theoretical Combo, for my theoritcal Car (getting a new job in a few months, can finally realized my dream after 4 years of high school and 4 years of college). What do you guys think of this potential at the strip, and did I miss anything? Thanks much in advance!!! BTW its for an 87.
1.) VDO Knock Gauge, VDO 30lb Boost Gauge, 1978-87 A-Pillar Double Gauge Holders, VDO Oil Pressure Gauge, VDO Water Temperature Gauge, Twin Console Gauge Holders
2.) FUEL PUMP HOT WIRE KIT
3.) Adjustable Fuel (Billet Aluminum) Pressure Regulator
4.) 340 WALBRO FUEL PUMP W/KIT
5.) 9" K&N Air Filter w/bracket
6.) 160 Degree Thermostat
7.) Breather Bypass Kit
8.) Block off Coolant lines to TB
9.) Scan Master Tuning Monitor
10.) Scan Master Shade
11.) Terry Houston Stainless 3" Down Pipe w/Dump
12.) Electric Exhaust Cutout
13.) 2 3/4" Dual Exhaust Kit
14.) ADJUSTABLE WASTEGATE ACTUATOR
15.) SMC Alchy Injection
16.) 009 Injector Set
17.) TA49, TE60, TE44 (Blue Tops or 009's Whcih with which)
18.) Front Frame Braces
19.) Under the Hood Braces
20.) Rear Seat Braces
21.) 2004R Orange Stripe 3000 Stall Speed Converter
22.) Stretch ic, or dutweiler neck stock ic
One more ques, can I use a more powerful injector with a stock setup and not have probs, Iie using 009's until I can afford to get a bigger turbo?
BTW, this site is great!
