Chicago Trans Builder
Now I Guess Its Easy For You To Understand Why Insurance Companies Wont Give A Smoker Good Coverage.a Build Without A Billet Drum Is Foolish And Doesnt Allow Maximum Third Gear Apply Pressure Which Results In Burnt Third Gear Clutches And The All Too Familiar 2/3 Flair.it Is Cheaper To Install The Drum Than To Remove ,repair And Reinstall The Trans Not To Mention To Tow The Car If This Is Necessary.brian Has Used Our Drums In The Past So It Is Obvious He Understands The Importance Of The Part.it Is Important For The Point To Be Stressed That If You Arent Willing To Pay For The Drum Than The Builder Shouldnt Be Responsible For A Repair If The Stock Drum Breaks Or The Third Clutch Fails.my Dual Feed Techniques And Drum Is The Absolute Correction And Answer To Forward Drum Breakage And Third Clutch Failure When All Else Is Working Correctly.the Dual Feed Doesnt Cost The Customer Or The Builder Extra ,but A Broken Drum And Clutches Does.
Brian
Brian is a Class Act with great customer Service and a Quality product,Same goes for Chris (CK),Brian will go that extra mile, you can advise and hope to Educate every one with your knowledge and track proven experence but you can't force someone to use it.......
Ed
