NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
Last fall I ordered an HID kit for my TR on E-bay. It was cheap so I figured it would come with some complications. I received it and discovered that 14 thousand K meant the headlights were pink. So I decided to order a 6 thousand K kit this spring with a 55 Watt bulb and ballast set up. The first kit was cheesy so I figured I would spend a little more on the second kit.
I have no idea who makes this stuff. I'm assuming it's probably an 8 year old girl being beaten in a sweat shop somewhere. But there's no company contact information, no way to request technical assistance and it's not worth the hassle of returning this junk. The instructions read like a poorly spelt Chinese menu. If you read them out loud you actually develop an Asian accent.
So here's the problem. Sometimes the brights work, sometimes the headlights work, sometimes nothing works, but most of the time everything doesn't work like it should. It's installed properly. You can't mess it up. It's Plug and Play. All my factory wiring rings out as it should. So the problem is in the kit. Now one headlight only is working on the driver's side. Last week it was the passenger side that worked.
I was told the ballasts were troublesome by a spectator at a car show. And he said sooner or later they would give me trouble. If anyone has experience with this sort of thing, and believes this is the problem, can you please direct me to a link for a quality set of 55 watt ballasts.
Otherwise any other ideas are appreciated.
