Chip performance questions?
Boostisgood
I am currently using the MSD 50# injectors with the JC 93 oct. street chip with 19psi. What kind of performance would i gain by adding the higher timing 108 chip? (assuming no kr.......3 and 2 mph? curious.) Would you recommend running more boost with the street chip or using less boost with the race chip? Just trying to get ideas before i start tuning. Thanks for any help.
Is this with alcohol? Or should this be in the chips 101 section? You may get more responses there
Although the answer to your question can be very broad, I will say that your chip is a critical component that has to be made to compliment your combination. Often this is only accomplished by making your own, or custom chip. A good example to help answer your question is a track experience we had. We went to the track, (87GN, stock IC/turbo) and had forgotten our hand tools. We only had our chip burner, so we used the evening to make 6 passes. After each pass we would make the chip changes based on the Directscan data. The ET's dropped from 12.79 to 12.30, no other changes being made. (consistent 1.7 60-foots) So I'm not sure what you'll pick up by just sticking in a "race" chip, but I hope you understand my point. :)
-Bob
I think Clay has NO2 in his GN unless he has put alchy in recently.
Clay I have this nice new chip burning kit I got from Bob :) Next time I see you we can talk about getting you tuned up. Im sure Bob can give us advice on what you need.
Dave
