Here is the deal. Installed new shift kit, GN servo, adjustable pin,
car would start out in first until I stopped and then it would start in second. I figured ban must be tight so out went adjustable pin and in goes old pin and springs with new GN servo piston and cover. The it would not shift out of first. I dropped the valvebody to inspect checkballs and found vb gasket jacked up. I replaced gasket, reinstalled v/b, checked tv cable setting. took it for a spin and the problem is now I HAVE NO SECOND GEAR MANUAL OR AUTO. The converter also continues to try to lock up and while in 2 or 3 unless I kill the switch. I never did that before. I changed the pressure switch and TCC for troulbeshooting and still same thing. Any ideas? I need to get this thing on the road ASAP. I thought of reinstalling adjustable servo pin just to see what happens. For whatever reason something is jacked up. I went fron having 2nd gear to not.
Thanks, Brian
Thanks, Brian
