SignUp Now!no, two piece and a washer, just did mineAre the CK servos a one piece unit ? Thanks RE.
CK is a well known vendor in NY.You guys are running a HD Intermediate Servo?
JOC, who is CK?
Many-Many years ago - I tried the Fairbanks Billett HD Servo Slide Assembly - and ended up removing it simply because it created such a radical shift when the Intermediate Band was applied.
The downshift via the servo was rather abrupt as well, and I knew it was a matter of time before something "broke" - like the Intermediate Retaining Pin - where the Band is retained to the trans case (under the valvebody).
I believe it was just redesigned. Search "there is a problem with every 200 4r' and read,the explaination lie there.
JOC, who is CK?
wiseman said:Are you sure they are 2 piece units? I just recieved my billet servo and it is a 1 piece unit that came with 2 shim washers and a gasket. P/N 24RCC/BS. It is powdercoated black. The pictured instructions that came with the servo show a different servo (a 2 piece) in the picture than the one I actually recieved. The pictured one is raw aluminum and mine is powdercoated black.
P.s sorry, for bringing reopening this thread, I was going thru some old threads and across this one
Yes they fit together very snug.There is no need to seperate them ,just follow the instructions.I am out of town ,will be back on Friday if you need additional informationBlow air lightly in the center hole and it will separate them. A one piece servo wouldn't work.
