CLEAN 98 Z28 6 Speed
deleonl
N.S.D.Q
Listed here is the inventory of the car:
BODY:
- ELECTRIC BLUE CORVETTE PAINT JOB, APPROX 6 MONTHS AGO
- CHROME 16X10: GM PERFORMANCE RIMS
- LIMO WINDOW TINT
- PIONEER AM/FM CD PLAYER
NEW FRONT CAMARO GRILLE
- SUNOCO COWL 3 IN RACE PERFORMANCE HOOD (ALSO HAVE THE ORIGINAL HOOD!!)
- NEW FOG LAMPS
- NEW FRONT AND REAR TIRES
- NEW BRAKES !!/ ROTORS – ALL 4 WHEELS, CALIPER BOLT PIN SET
- NEW METALLIC GLOSS BRAKE PADS
- NEW T-TOP CHARCOAL SHADES
- NEWLY WRAPPED SUN VISORS
- NEW A-PILLAR POD
- NEW MECHANICAL NITROUS GAUGE / AIR-FUEL / OIL PRESSURE GAUGE SET WITH CAMARO MOUNT
- LEATHER AND INTERIOR CLEAN
ENGINE / HIGH PERFORMANCE PARTS:
- SLP SHORT-THROW SHIFTER
- NEW SPEC-3 RACING CLUTCH
NEW ALUMINUM PLATED FLYWHEEL
- NEW PRESSURE PLATE
- NEW SLAVE CYLINDER
- NEW SLP LID INTAKE
- LS6 INTAKE MANIFOLD
- PORTED/POLISHED LS1 HEADS
- NEW / UPGRADED CAMSHAFT: COMP CAM 224/224 112 LSA
- 42LB FORD RACING INJECTORS
- RACETRONIX 255LTR FUEL PUMP KIT WITH WIRING HARNESS
- PACESETTER LONGTUBE HEADERS
- BORLA CUSTOM X-PIPE EXHAUST
- TRUEDUALS WITH 1 CHAMBER FLOWMASTERS WITH 90 DEG. TURNDOWNS
- MSD NITROUS ACTIVATION WINDOW SWITCH FROM 3200-6400 RPM’S
- N.O.S. DRY KIT NITROUS SYSTEM WITH 100 SHOT PILL (ENGINE IS BUILT TO HOLD 150 SHOT); ( I ALSO HAVE THE 200 PILL SET.)
- NEW A/C SYSTEM INCLUDING AC COMPRESSOR/EVAPORATOR/CONDENSOR/COMPLETE SYSTEM EVAP & RECHARGE WITH NEW ORFICE TUBE & ACCUMULATOR, HOSE (BLOWS ICE-COLD)!!
- FORGED INTERNALS WITH DIAMOND PISTONS
- NEW WATER PUMP AND RADIATOR
- COMP CAMS 918 SPRINGS SET FOR CAM
- COMPLETE GASKET KIT WITH ALL SEALS
- COMPLETE HEAD-BOLT KIT
- COMPLETE MAIN-BOLD KIT
- LS6 OIL PUMP
- TIMING CHAIN / GEARS
- CRANK BALANCER BOLT
- ROD BEARING SET
- MAIN BEARING SET
- CAM BEARING SET
- PISTON RING SET (OEM PERFORMANCE)
- CONNECTING ROD
- LS1 PREPARED STOCK CRANK
- HONE CYLINDER AND INSTALLED CAM BEARING SET
I HAVE VARIOUS EXTRA PARTS STILL IN BOXES:
STOCK WIRING HARNESS, N.O.S. PILLS, TUBES, BLOWOUT / PURGE VALVE, NGK PLUGS – FLARE JETS, STOCK CAMSHAFT, STOCK HOOD, GEAR SHIFTERS (HURST HANDLE), AND MANY OTHER MISC ITEMS.
I HAVE RECEIPTS FOR EVERYTHING MENTIONED IN THIS LISTING.
THE INSIDE OF THE ENGINE AREA IS EVEN SIGNED BY THE INVENTOR OF CAMARO.
I USE THE CAR AS MY DAILY DRIVER TO AND FROM WORK EVERY DAY, STILL GETS GREAT GAS MILEAGE.
Contact me for pics, I have no idea how to post them sorry.
Email me at louis.deleon@us.army.mil
$9,000
Louis
Cell: (813) 309-0144
That sounds like a really nice ride and a Hell of a Good deal, Good luck with the sell.
Damn...I should have checked this forum earlier...oh well.
Nice ride...don't have any old pictures do you? Just curious.
JC
