Cleaning Stock Injectors
Rick
Senior Member
I'm going to temporarily put my stock injectors on an engine I just bought. I'm going to put new rubber O rings on them and was wanting to clean the outsides of them off. Is it OK to soak them in cleaner or should I just use a rag and degreaser?? Also, are the clips necessary, I'm missing two.
Is it okay to use Vaseline on the O rings to get them to push in easier?
Hello wall, my name is Rick, how are you today??
Cleaning?
Rick, you can clean the outsides w/ carb cleaner.. It will take the grease, crud and the paint off.
You can change the o'rings on the top. The lower o'rings require a new backup washer and pintle cap.
There's also a filter basket in the inlet that should be changed.
The o'rings are available.. the rest of the stuff is done when the injectors are totally cleaned and flow checked.
I do injectors here at my shop. I have used, stock injectors already cleaned, flow tested, wear items replaced and painted for $90.00 a set plus $5 Priority mail, NO exchange is needed. I can ship next day after receipt of MO.
If the inj's have been laying out and have had gas in them, they are most likely stuck shut or in a condition that will not allow them to operate correctly.
ANY inj that has rust inside it is JUNK!! I look for that first and throw any away that are so affected.
You can go some mid 12's w/ these stock injectors and they have a great life expectancy.. I've cleaned ALOT of them at well over 150,000 mi and they operate as new when done.
Yes, you can use vaselene on the o'rings.:cool:
