Cleaning ttype wheels
ssleeper94
will it run?
Is their any way to clean the wheels on my ttype, I tried just basic rim cleaner but didn't do much still has what appears to be embedded brake dust. Is thier any product that'll clean the rims and get rid of all the dirt and dust on the rims.
When I had my 87 T, I used this stuff called alum-bright. I bought it by the gallon at Carquest. It's very acidic, but man, the shine on those stained rims were unbelievable. This stuff is perfect for older wheels that do not have a clear coat on them. Just don't inhale the stuff, and be sure to wear gloves or be sure to wash your hands immediately after use.:eek: :eek: :D
ttype wheels
go in your bath room get out the toilet bowl cleaner you get at the dollar store not spray /liquid squirt on set two mimites hit with brush spray off with lot of water try it you might like it
Eagle 1 aluminum etching wheel cleaner and a brush. Over the years it has turned my wheels almost white though....once the clear starts letting go this will remove it in time
