Has anyone figured out a good way to clean them? Mine is in good shape, no tears or anything, just a bit dirty. I dont want to shell out big $ for a new one, and the aftermarket ones look so cheap. If anyone has any advice, I'd appreciate it.
SignUp Now!I removed mine from the car. Wet it down with hose, not high pressure! Sprayed it with Simple Green & let it soak. Then used an old towel with a soapy bucket of Dawn dish detergent and gentley washed in down, rinsed thoroughly and let it drip dry for several days. I put some rubber hose around coat hangers, so that it wouldn't tear out the holes and suspended it until dry.
Great, thanks Bob. If it's good enough for a GNX, it will do for meDid you reuse your clips, or did they break on the way out?
I found a picture.........
My lord that car is immaculate. Random question for ya...what wax do you use? That car is shining nicely :biggrin: Also was the tranny cooler stock?
Thanks, I use Turtle Wax Ice. It's great on black, it can be applied to everything: paint, rubber, black trim... everything. It does not leave a white residue. Yes, that's the GNX tranny cooler.
Bob:
I wonder if you have any "before" pics. The hood pad looks great but I wonder how dirty a GNX hood pad really ever gets? Compared with the GN and T's, I usually find GNX owners rarely drive the cars much less get them dirty.
Not bashing or anything, just curious as I'd like to clean mine up as well...
So I gotta ask a new question...you mention "rubber"...so you apply it to your tires?
