Code 12
Flippittyflops
I just got my gn running today and the service engine soon light is on. I checked the code and its code 12. I was wondering how to clear the code? Thanks Kevin
If you have code 12 and the ses light is on, your going have to wait for the code to come up, and then it flashes 12 to end the process.
Common problems, people unplug the wastegate solenoid and the air inlet temp sender, these codes will pop up if you wait for the process of retrieving codes
BW
To clear any codes you jusy need to unplug the orange wire connection that is near the battery.
Yeah, but if the check engine light is ON and he sticks a paperclip into the aldl then he isnt doing the process correctly... He isnt waiting long enough.
IE: THERE WONT BE A CHECK ENGINE LIGHT FOR CODE 12
BW:)
