My car had started running rough and throws a code 32.
I checked the EGR and find that the valve is pulled open at idle. My understanding is that it's supposed to be closed at idle and the solenoid allows vacuum to pull it open when appropriate. Disconnecting the vacuum line to the valve, the plunger closes and the car runs smoothly.
So it sounds like the solenoid is inappropriately allowing vacuum to the valve when it's not supposed to. Any thoughts on why this is occurring?
I don't know for sure, but would guess that a "broken" EGR solenoid would be stuck closed and not allow vacuum to pass. Makes me think something else is telling the solenoid to stay open. Any idea what that could be or how else to further diagnose this problem?
Edit - Just a thought. Could this just be a weak EGR valve spring? There is vacuum definitely passing through the solenoid, but is seems pretty weak (gotta put a gauge on it to see how much vacuum). Maybe the spring is weak allowing this small vacuum to pull the EGR valve open when the spring is supposed to be strong enough to resist it? Just a thought
