Well, I went out testing tonight and I started to get a consistant code 32 after each WOT pass. Got it 3 times in a row. I had that code pop once on me at the TA Nats a few weeks ago. I was hammering on it a few times up there but never had it happen at each thrashing like today.
I was reading gnttype.org on the code, pretty much the same thing the turbolink help said. Is cleaning the thing out ever effective or should I just start calling and order one? The vac lines look good but I did not get real close, the engine was hot. Is there one that it subject to poping off I should check first since it seems the code is set if a switch is not closed based on a vac signal.
Brent
Brent
