Interesting, I am getting an intermittent Code 42 as well. PLC shows it as an EST monitor error, wondering if it could be pin A (EST) or pin B (BYPASS). I was going to pull the ECM harness connector, guess its easier to check resistance at the module connector first. What method did you use to repair the broken wire?
