I'll keep it simple. I may know what the problem is already, but want to "double-check"
Swapped in a set if ATR headers along with some other stuff, like oil lines and crap. After I buttoned MOST of everything up, I wanted to start the car WITHOUT the IC in place so i could ceck for fluid leaks first. With the IC in place it would have been a PITA if I had to take it out again. Anyway, I have the MAF pipe going to the turbo sealed up but that was it, nothing going to the TB. Started the car right up, no problems...after a few minutes it threw a code 45 and basically died. Now, the O2 sensor is a fairly new Denso, so I'm almost positive it's not the problem.
Would not having the IC and pipes hooked up do anything?
If not then I suspect my MAF...BLMs were pegged at 90. I had a feeling it was on it's way out last year. Now I guess it's officially dead
Ugh
Ugh
