I got Phase 1 of my "electronics modernizing" project completed last night. I bought an ALDL 12-pin Bluetooth adapter from
www.1320electronics.com previously, but only mounted it temporarily. Plugged into the ALDL port with the thick data cable coiled in an ugly loop at the front of the console and the coiled phone-cable power line plugged into the cigarette lighter. I wanted to conceal it somehow so as not to attract attention from potential window-smashers thinking it's a radar detector or something valuable. It's not worth much but it's definitely not worth a break-in. Also, I didn't want to have to plug into the cigarette lighter every time I drove the car, because the receptacle is powered even with the car off so leaving it plugged in would drain the battery.
I made the following image of the fuse identification, location & amperage after a bunch of research and not finding all 3 bits of info in one place. It helped me find a spot to plug into for ignition-on power. I plugged into the IGN 1 plug to the left of fuse G and ran a wire over to the front of the console.
I found a good spot to conceal the Bluetooth adapter: after removing the ashtray, it would
almost fit in the niche beneath. I probably could've shoe-horned it in sideways, but I wanted to be able to see the lights & access the dip switches if necessary, so facing up with the wires down would be perfect. I had to cut a notch in the plastic lip at the bottom, then the adapter slipped right in. I stuck on some foam tape strips to stop it from moving around.
The data & power wires tucked in neatly down along the left side of the shifter bracket and now, all you can see is the ALDL port connector and a bit of the data cable, and nothing plugged into the cigarette lighter. While I had the console plate off, I took the time to clean everything inside & out, in particular the corrugated plastic shifter strip which was full of crud. I also learned why the shift indicator light stopped working sometime last year; the bulb was good, but one of the connector pigtails was torn off. The local parts store wanted $34...you heard that right,
34 bucks...for a single connector! I saw them on eBay for $5 but I ended up just soldering fresh wires into the connector.
I also bought some blue & green LED bulbs to replace the 194 bulb...need to wait for them to arrive to see which one looks better.
Turned the key to "on" and it comes to life:
