Coil pack mystery solved!
TampaTurbo
I would assume it is a logical conclusion to say the coil pack and module is bad when the tan epoxy is leaking out of the module? That stuff is sticky too!
Swapped in the one I had on the shelf and now we can let the smoke out of the tires again.
Factory setup was connected to the turbo inlet. Been some conversation that it is better to leave this in place rather then to replace with a open air breather.
If you've got stuff oooozing from your junk, it's definitely not a good sign.
you can go and get a new style coil pack off of an new style vehicle because they have the same plug . lik one off a vehicle with a 3800 series 2 or better yet you can get one setup with a 3800 series 2 with the super charger on it .:cool:
