coil pack
a.j.hogan
hey guys,whats the best way to check my coil pack out to see if is bad.thanks a.j. hogan
checking coil pack
Hey, I think that you need to get a volt meter and check the ohms from side tower to another side tower and if it is below 13ohms I think it is good, but its just what I remember so it could be wrong. Matt
Check resistance with volt meter, should be between 11k-13k ohms across towers. Or get Casper's coil/module tester, good product.
