COLD coolant lines to throttle body
redhotrod
Turbo Happy
Hey, just a thought while I was rebuilding my turbo, Has anyone ever tried putting something colder than the antifreeze through the coolant lines to the throttle body. I was thinking like something like alchohol injection, where you could switch it on for drag racing or something like that, or use freon. Is this feasible? I understand it would get hot after a while due to no radiator to cool it, but just for maybe 1/4 mile runs at the track.
Can't wait to get this turbo back on, went and ported and polished the turbo. Even polished the outside of it, looks really sweet!
:cool:
:cool:
Yes, I HAVE
I have unhooked my throttle body coolant lines from the stock hook-up, I now use the two 5/16" Steel stubs on the heater pipes to cool water jacket turbo bearing housing,
BUT I have a home-made Cooling system on my HOT air TURBO RIVIERA,
I have a 6 pack cooler behind the driver side headlight location Filled with Washer fluid and Bulge pump, THE pump has two circuits of cooling paths, One is 10 feet of 5/16" copper tubing wrapped around my turbo intake adapter, then plumbed into my throttle body coolant lines, The other cooling path is a 4"X 4" cast conduit box with a blank cover and (2) 1/2" pipe thread hubs on it SITTING on top of the Hot air INTAKE. THE first circuit returns through a front mount transmission cooler, I can put cold packs in the Cooler also.
THIS sounded like a good idea a the time, how much it helps ANYTHING is up for debate!!
Regards
