Cold start idle problem
Murphy3081
Hey everyone, I have an 87 GN. Lately in the cold weather its been having problems on a cold start idleing. On a cold start it revs high then goes low then back to high then low etc. It often idles so low that it stalls out. Once the engine is warmed up in a couple minutes the engine runs normal and starts up normal as well. During cold starts I have to keep my foot on the gas untill it warms up a little to keep a smooth idle with out it stalling. The MAS is good and the IAC valve is new. Any ideas for a solution would be much appreciated, thanks.
  • Like
Reactions: FWC
Is the IAC valve set correctly? Do you have a scantool? If you do what are the IAC numbers?
hey everyone sorry for the late response. i used the reset procedure and reset the IAC. the numbers are all correct. i noticed it now has a smoother idle. however on a cold start it is now running smooth for about a minute then just stalls out unless i keep my foot on the gas. vacum leak maybe, wiring, i also read somewhere a fuel injector problem?????
Could very well have a vacuum leak but it sounds like the iac or tps is still out of wack.
How did you set them? Whats the iac number warm at idle?
It idles smooth then stalls. It only takes a minute or two to go into closed loop. I had this exact same symptom on my 87' and it turned out to be a bad O2 sensor.
ok thanks for the input. i am going to look into all of this. i am running with the stock chip. is there any way to know when they are going bad besides the messed up idle-stalling.
Stock chip... I knew it! lol....Then your car is running normal... assuming, like you said, that the iac and tps are set correctly, and the numbers are right.... the chip isn't going/doesn't go 'bad'.... it was just a fairly crappy calibration from the factory... My car ALWAYS died at least once in the morning when it had the stock chip, since brand new.... everyone's did.... do yourself a favor, and order a chip from TurboTweak.com, and believe me, your car will idle, run, drive like you never, ever thought it could.... night and day difference, for real! Best, what, $75?, you ever spent....
hahaha yeah im going to def check that out, i ve been holding out to look for a new chip but this put me over the edge. i didnt realize they were that cheap. i need to gather all the numbers/info together
Try grounding ALDL connector, then unplug IAC motor(with key on, engine off for a minute),start engine, adjust idle to 600-700 rpm, reconnect IAC, clear any codes then adjust TPS to .46-.52
As I remember that worked well. good luck.
Kevin.
  • Like
Reactions: FWC
i did that when i reset the IAC. i did notice a more smooth idle but still on a cold start it stalls after about a minute.
Yeah, like Brian mentioned earlier, stockers were a little "cold-blooded", if your good on all adjustments, might be the time to "Update' the software, lots of improvements in 20+ years, I am completely out of date with all the Mass-Air combos but the real braintrust is in one of these rooms, lol :biggrin:
Good luck.
Kevin.
The stock chips went into closed loop pretty early...I think around 89 degrees which made them pretty cold blooded. Definitely get one of Eric's TT chips. That's why if your O2 sensor isn't up to snuff it will stall when cold.
im getting a new chip and we will see how that goes, ill let you all know. thanks for everything.
Hey everyone im sorry for the delayed response. I got a new chip and put it in. It now runs awesome, no more stalling, better than before. Thank you for all your assistance!!!
