I have an 87 Gn bone stock with 120K on it. I replace the MAF hose, turbo. inlet and outlet hoses (all the above were worn and leaking) New DIS mod and coil, new 8MM wire and plugs.
Before and after replacing the above I still have a cold start stall. The engine will start, tach up to cold start speed about 8RPM? then slow to the normal idle...loop a little then stall out. It can be immediately restarted.
There are no DTC and MIL on. The vehicle idles well when hot. I think I have an IAC issue or IAC adjustment issue. What do you all think?
